Installed a 16GB Sandisk class 2 card and synced FLAC files in MediaMonkey. The Fuze+ won’t load the card. Whenever it tries, it takes about 2 to 3 minutes and then reboots. It does this over and over and never loads with the card installed. It’s updated to the latest firmware.
Wow! The problems are multiplying. Now, whenever I plug in the Fuze+ to USB port on my PC, it powers off. It won’t power on while plugged in either. Looks like a refund is coming and no more to be bought.
First, try removing the microSDHC card and isolate whether the issue is with the “external” memory. As the files are from MediaMonkey, they should be fine, check your settings for the ID3 tag output. Use ID3 v2.3 ISO 8859-1 fo your output format.
Also check if you have any notes in your FLAC files.
Bob ![]()
