The Fuse really doesn’t need a case. It defeats the purpose of a slim player. It should actually have a screen protector included. What a shame Sandisk didn’t include one.
Not so, IMHO. With my skin, it protects the player and only adds a tiny bit to it’s total thickness…and the ‘grippy’ feel the skin gives, makes it more secure in my old hands (LOL). Screen protectors are a dime a dozen. Even my local grocery store carries them. They aren’t exactly designed in size for the fuze, but are easy to trim to get an exact fit.
I was considering this: http://www.amazon.com/Transparent-Clear-Crystal-SanDisk-Sansa/dp/B001ECP666
I just saw that the invisibleShield site has a 50% off coupon. The Fuze is listed.
Deal:
http://slickdeals.net/permadeal/17148
Product page:
How about this…can you replace the original front material? I mean like a skin for your nokia…
Great idea. I’d like to replace mine with a stainless steel faceplate and a scratch resistant sapphire window.
I think Sansa Fuze Crystal Case is good cause it has screen protector attracted to the case and have a hard shell outside can protect away from scratching or dropping.
like this http://www.handhelditems.com/sandisk-sansa-fuze-crystal-case-clear-p-14287.html
All I can say is Diamond Plate Steel, Problem is that I would probably break my fuze to bits when I would try to switch them out. maybe a clip on of some type. Somebody who could make a prototype and get this marketed could make a mint off of this thread!
That’s the one I posted.
I played with one today. I liked it but I like the Rubber Polymer one, Amazon and Searc Sansa Fuze Accessories (they are like 6.59 New plus Shipping)
I want the screen to be protected though. I don’t want to drop it and shatter the LCD screen.
The only Drawback I could see, I am willing to deal with cutting up the adhesive ones that they make for other players.
Unless you have that hard plastic, the screen can still break. I know someone who got a 120 gb zune or whatever for Christmas and already broke the screen.
Ive decided to take my chances… I have had Sansa Connects, the first one Froze and was ruined, the Second one got dropped on ceramic tile the player shatterd but the screen was fine, and the Connect I have now, has been dropped a few times and I have no Screen Issues. I have yet to drop my fuze but I seem to have decent luck.
Use this code for an additional 50% off!!! SHOWSP09
They have sandisk models availible…
http://www.zagg.com/invisibleshield/media-player/sandisk
but I chose one os these instead and plan to cut them up several times!
http://www.zagg.com/jonk/inventoryblowout.php
Choose the larger ones for the best deal and then cut them to fit as you like for either full face or just screens!
about time the price is down for these shields.
BTW if you are close to an Ocean State Job Lot store you can buy the shields by Targus. 5 to a pak. each large enough for 2 screen applications (ie 10 shields aftert cutting).
Cost is $1.59, or 16 CENTS per shield.
Message Edited by noki on 01-07-2009 04:17 AM
Shields are stupid. I probably won’t get it scratched ever. I’m more prone to dropping it if anything.
I used the code and paid like 6.50 with shipping.
Here are a few pics of my 4GB Fuze in its new polycarbonate plastic case ($4 on eBay). It’s a smoke colored case, but may be kind of hard to make out in these pics.
I’ve found this case to be better than my other one (compare to my earlier pics), as this one allows for better access to the power switch, microSD slot, and especially the sync port. The cable actually fits all of the way in this time!
Also shown are my JVC Air Cushions and their inexpensive carrying case.
http://i6.photobucket.com/albums/y247/ChironHeroTeacher/DSCF0066.jpg
http://i6.photobucket.com/albums/y247/ChironHeroTeacher/DSCF0071.jpg
http://i6.photobucket.com/albums/y247/ChironHeroTeacher/DSCF0074.jpg
http://i6.photobucket.com/albums/y247/ChironHeroTeacher/DSCF0079.jpg
All the best.
Message Edited by HulkSmashNow on 01-13-2009 08:34 PM
mmkk so i used 2 have a e200, but uh, i kinda put a big crack through the middle of the screen, by acident! and then months l8r it just stopped working. anyway i got the fuze for christmas and would like to prevent any future screen craking i might cause, so does anyone recomend any cases? something that will protect the screen from my damage prone hands.
