I am looking for a case or someting for my Sansa fuze so I do not drop it is there anything like that.
If a case you desire, the Google you must use
“Sansa Fuze case”
I took some thinner foam that I had around and hot glued it to the inside of an Altoid tin. It fits like a glove and works very well. I have dropped it a couple of times with no problems.
Here are some:
http://www.bargaincell.com/search_product.php?keywords=sansa+case
I went for the crystal case.I as happy with it so far
I use a tiny micro-camera case from Lowepro with a velcro flip top. Goes right on my belt. Works fantastic and also holds earbuds.
I got a very cool 3-in-1 case from Handstands (bought through Buy.com). I think it was about $15. There’s a leather case that has a belt loop, and arm band that also fits through that belt loop if you like, and a hard case that the fuze-in-leather case snaps into (also holds your earbuds). I like the hard case because I can toss it in purse or gym bag with no worries; earbuds dont tangle, and I can pop the fuze out for listening. Holes in the leather case allow access to all buttons and ports.
