I tried to fix the problem with my sansa clip not freeing space even though I deleted music files. I read a support article that was probably ment for usb-memories or something - not music players.
Slide the hold/power bar to hold, and then press the center button and keep it pressed while plugging the Clip into USB. Then run the Sansa Firmware Updater:
I formatted the device, and now I can’t use it at all.
Is there any way of reinstalling the software? I can only find updates.
Thank’s for listening!
Kajsa
The updates each are self-contained–they are revisions of the original firmware. You can install the latest “update” and it will work fine in and of itself. (I guess the better name would be, “Updated firmware.”)
