im tring to fill my cruzer blade up with avi files sized around 1.5gb, i can only fit around 7 gb worth on there then any other avi files i try to put on there,it says corrupt file( even though if i had put that file on as one of the first 7 then it would have gone on fine) it says i have 23gb left. Help Please!! btw its format fat32.
This is interesting. But you can still save it there right? It would just say corrupted? Have you tried formatting again to FAT32? Try NTFS too if it would make a difference.
“any other avi files i try to put on there,it says corrupt file”
What is “it” that says corrupt file? Is the “corrupt file” added to the Cruzer and if so can you add others? Are you sure the files are less than 4GB?
