write protection
i have sandisk blade 8gb pendrive and its write protected, so anyone tel how  to remove write protection
SanDisk Customer Service / Tech Support
Check this KB first. http://kb.sandisk.com/app/answers/detail/a_id/1102/~/memory-card-is-write-protected-or-locked If still a no go, I would check my warranty here.
i have a sandisk pendrive with 8GB. Then now when i connect this with computer  i can’t format ,write ,copy , delete anything from this drive. when i format this pendrive it will show the write protection problem. so i kindly requesting to u to give a proper solution to this problem…
I see ppl saying their problems… Can anyone share a solution for this…
I’m having the exact same problem with my Cruizer 4GB. I’ve tried every solution I’ve come across, and nothing has worked.
Then return it.
And if returning it to the store isn’t possible, return it to SanDisk.  See this post for the URL.
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/8Gb-Cruzer-edge-waste-of-money/m-p/291480#M4373
I have an Ultra 32GB USB drive that has worked fine until about 2 days ago.  Now it is read-only on my Windows 8 machine and an XP machine.  Other USB drives work fine and do not show as read-only.  BitLocker shows it as read-only but as unprotected, and gives no provision to unlock it.  I have even loaded the MBAM program to no avail.  How can this be fixed???
"How can this be fixed???"
Read posting above your’s.
