Problem with Sandisk Cruzer Blade 8GB.
  Hi…
     I have bought a new sandisk cruzer blade 8gb.I have copied all the folders and applications came within it.I have not installed them.My OS is windows7 home basic.I have formatted the pendrive and copied a movie in it.From then it became write protected.I could not copy or format it anymore…It is saying that it is “Write Protected”…What to do? How to remove this protection…? I want to use it as a normal pendrive working with all OS without any problem…My Sandisk is SDCZ50–008GB…
I think this has a U3 feature. Try turning it off and see if it makes a difference. Good luck.
SanDisk hasn’t made a U3 drive since 2009.  I seriously doubt the new Blade has U3 on it.
sir my Sandisk Cruzer Blade 4GB. is not format it’s shows the write protected… please help…
SanDisk Tech Support Global Contact Information
sir my sun disk 4 gb pen drive is not formate…
it’s showes the “the disk is write protected”
please give the soluction…
"in my case i’m format the pen drive in locked mode "
“before formatting is not remove the SanDiskSecureAccess”
and that time it’s formatted and after again formatting it.s not farmatted its shows the “the disk is write protected”
please help me…
how to format my 4gb pen drive…
Are there any files or folders on the pen drive?
Are you able to see Hidden files or olders with your Windows Explorer?
What operating system are you using?
Why do you want to format the pen drive?
1- only 1 corrupted folder in my pen drive…
2- no Hidden files in my pen drive…
3- i’m windos x.p are using
4- because of new deta will be transfer in pen drive…
“sir one think i,m clearing to you (i’m format the pen drive in locked mode)”
(i’m  not remove the SanDiskSecureAccess in format time)
that why it will be accurring this type of problem…
:slight_smile:
1a. Insert the pen drive.
1b. Open a Command Prompt window
1c. Enter the command:  attrib ?:*.* where ? is the drive letter of the pen drive
1d. RIGHT click on the top of the Command Prompt window and select Edit then Select All then press Enter.
… This will copy the text in the Command Prompt window to Windows’ Clipboard.
1e. In your reply here click on the Insert Code icon then press the Shift+Ins keys. (or Ctrl+V )
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Administrator>attrib a:*.*
Close but a: is not the drive letter of your pen drive.  Repeat the steps with your pen drive plugged in and it’s drive letter in the command.
C:\Documents and Settings\Administrator>attrib j:*.*
After keying in the command you have to press Enter.
You should see something like this:
Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Users\Ed\>attrib J:\*.\* A H J:\BOOTLOG.PRV A H J:\BOOTLOG.TXT A R J:\COMMAND.COM A J:\AUTOEXEC.BAT A J:\CONFIG.SYS A SHR J:\IO.SYS A SHR J:\MSDOS.SYS A J:\PortableFirefox.lnk A J:\PStart.exe A J:\autorun.inf A J:\PStart.xml C:\Users\Ed\>
no sir
after enter “attrib J:*.*”
it’ shows the file not found - J:*.*
sir its shows the disk is write protected…
“it’ shows the file not found - J:*.*”
But you didn’t post that when I asked you to post the output of the Command Prompt window.
That error indicates either:
the pen drive is not plugged in,
J: is not the drive letter of the pen drive,
or there is no corrupt folder on it.
OK.  But what is the drive letter of the pen drive?  It’s obviously not J:.
Insert the pen drive then click on My Computer.  What letter is associated with the pen drive?
