I’ve tried reseting the player by holding the power switch but nothing happened. Any ideas what is the problem with my player?
Also when i disconnect it from my pc it shuts off
Other posts on same topic suggest a disconnected battery wire. If this is a new unit return it, else search for similar posts. I gather you can open it up and fix if you have confidence in this type of thing. If it’s a bad battery you can get a replacement, anything else and you might be out of luck.
