Okay, well, my Sansa turned off on me during a song. I took it home and plugged it into my computer and it did nothing! and just yesterday it did! what happened?
And just yesterday it did what? Worked? Did nothing? Turned on?
Have you tried resetting it?
My clip 1GB Sansa did something similar to me. Was working well had low battery. I connected it to the USB to recharge the battery and after an hour or so tried to turn it on without success. I have tried different PC USB ports, different USB cables, I have also tried the wall charger and all of this without sucess. I have tried also resseting the player with the on button hold for more than 30 seconds.
The player stills death and doesn’t seem to recharge the battery. The player is relatively new just got it for Xmas last year.
I’m running out of options here, any recommendation will be helpfull.
Thanks.
Call SanDisk Tech Support.
