I’ve got an 8GB Sansa Clip that has worked absolutely fine for the year or so that I’ve had it. But it now will not turn on, or be recognised by my computer at all. This was all out of the blue. Was working perfectly last night, it hasn’t been dropped, removed incorrectly from computer or had any contact with water.
I’ve tried different USB ports, and cables, on two different computers, one running XP and the other Vista (it’s previously worked on both). I’ve tried holding the power button up, holding the volume + button, holding the centre button…all to no avail. Any thoughts/advice would be greatly appreciated as I’m lost without my mp3
I plugged Sensa Clip into PC speaker then I took a nap. When I wake up, the Clip was off, completely off. I can’t turn on or connect with pc anymore. Does anyone know how to make it works again
Your problem is the sansa is dead The Battery Must Have Compleatly died When you plug in the sansa after a complete drain of the battery The PC Won’t Recongize The Player Will After A Few Minutes Reconize The Player Will Charge But Will It Will Take A While Don’t Worry You’re Going To Find All Your Music Back
