If you have the playlists already created in WMP, you simply go to the Sync tab and place the playlist (The Title not the individual songs) in the sync list. Hit sync. Should work fine. If not what version of WMP are you using?
Sorry, but that doesn’t work. I have 3 play lists defined in Windows Media Player, and it still tries to sync the whole 100GB over to it, ignoring the playlists.
What Firmwire do you have? Also are you using an SD card? I had issues with both things before I upgraded. I had a similar issue, mine didnt load my whole database but It would not do playlists. Also As Marvin suggested you may have some settings out of wack. If all of this lines up and you still have an issue, I am stumped.
Okay, found it, and yes, now I can sync each playlist independantly, so as only syncing what I want to copy over.
My next question is, how do I get it to recognise the playlist, because its playing them in alphabetical order, and not in the order I listed them in the playlist.
ok so you copied the playlist title into the sync tab, it synced and now its playing alphabetically and not in the order on the playlist? I have no Idea… I jsut noticed for the first time it did that to 1 of mine as well. I may try to re sync it but I am not sure why it did that. My settings match the recomended.
Message Edited by Conversionbox on 12-11-2008 02:36 AM
From here on, I can’t help you, because I don’t use playlists. Glad you got rid of the auto-sync though:smiley:
i posted this on the first page as well but It may have gotten lost. so…
Found the solution, it only seems to copy the playlists if its in MTP mode. not MSC mode. I changed it to MTP mode, and resynched it, and the playlists appeared.
Actually, WMP automatically syncs the entire library. If you go into MTP mode, then go to the down arrow on the sync tab in WMP 11. Go to Sansa Fuze and then click setup sync. Now you can choose what automatically syncs to your Fuze.
Your best bet , of course, is to set it up to not automatically do anything
Correct you are! I would just set it up to sync “Files I Added”. Unless you have playlists that you frequently change. Then it would be nice because it will add files or remove files added to or removed from the playlist.
