Hey guys. Thanks a ton for the FLAC support with the latest firmware update. I’m really excited.
I do have a question, though. Which modes/combinations of resolution and sampling rate of FLAC does the clip support? I just upgraded, and tried the FLAC test files from Gimell Records (http://www.gimell.com/musicstore-download-test-files.aspx), and the only one I could get to work was CD quality (16 bits/sample, 44.1 kHz sampling frequency). Obviously because it’s stereo out, I didn’t expect the 5.1 modes to work at all, or if they did they’d just mix down to stereo. That’s okay. I was kinda hoping for 24-bit support at least, though, even still at 44.1 kHz sampling. Am I doing something wrong? Does this updated firmware work with any of the other combinations? If not, are there plans?
I’m using a rev.1 4GB Clip.
Thanks again for the firmware update,
Lloyd
