Dear Friends, Can you help?
I have had my 2gb clip plus for a few months now and have added a 16gb Microsdhc (sandisk).
Firmware is up to date.
I’ve had niggling problems from the start, but I’m now coming to the end of my tether!
In MSC mode, as recommended, I drag and drop my albums (from CD via Media Player or EAC) in Explorer (Win XP) to the “H” drive, aka the sdhc. I “safely remove hardware” unplug the Clip +, refresh my media, and find only about four or five albums of the ten or so I copied over are there! Any further albums I try to add also disappear into the ether.
I’ve reformatted the Clip+ several times, formatted the micro with both Windows and SDFormatter (which took hours!) and – Bingo! - Same problem.
The micro card shows as 15.whatever gb it should in the Clip+, and the PC.
It doesn’t seem to be a tagging issue as an album that disappears on one download to the player, will quite happily play on it (if it is one of the Chosen Few) after a reformat and fresh download. Meanwhile, an album that used to be on it, and I’ve tried to put back on, has done a Houdini!
Any suggestions on this would be gratefully recieved.
Be Happy!
