I’m running Vista. After installing the firmware updater and plugging in my Express everything works ok, meaning the litle white box appears in my system tray. After a reboot I can see sansadispatch.exe running in my system tray but when I plug my Express in no little white Sansa updater box appears. If I stop sansadispatch.exe with task manager and run it manually with admin rights and in xp service pack 2 compatibility mode and plug the Express back in it works again.
Any ideas about how to have it automatically work (without having to restart sansadispatch.exe)?
Also what is starting sansadispatch.exe? I have a number of tools that monitor and display startup programs via location or registry entry etc, but I can’t locate where sansadispatch.exe is being automatically started from… seems kinda of strange or sneaky or clever depending on how you look at it.
Well rest assured, they haven’t started a global takeover of everyones computer… … … yet?.. But anyway, the updater will only appear when there’s a update available… normally. If you’re having trouble, try to uninstall it and reinstall… as for what program or process starts it… not too sure about that one myself…
I have an issue with Vista 64, I installed the Sansa Updater as admin… now, every time I boot up, the UAC comes up asking if I want to allow it to run. Any advice to remove this annoyance short of turnng UAC off?
