My drive works fine in my computer. I can’t view the pictures or video on my television though. I am able to do it with all my other drives. The drive I’m trying to use is Cruzer 2.0 16 GB.
Does the tv have a size limitation?
Also, try to format this as FAT32. I’ve got this once on my Samsung TV. I had NTFS set on the flash drive.
"try to format this as FAT32"
Don’t you mean REformat it back to factory format, since all flash drives are formated that way?
However if the OP has video files larger than 4GB he could have indeed formated the flash drive to NTFS to accommodate the larger files. Unfortunately with the lost of the TV’s access. A good point to consider when shopping for a new TV.
