Video4fuze does not work ( what should I do)???
It skips frames and has an error at the end
Post here:
http://forums.sandisk.com/sansa/board/message?board.id=sansafuse&message.id=37541#M37541
It has to skip some frames to convert for the Fuze.
Check the Video4fuze thread.  You can ask ssorgatem for details, if he’s available.
Patience, Grasshopper.
µsansa
The first time I tried it, it seemed not to work either.  But, it turns out that skipping frame messages are normal for this thing, and any interruption that you do (closing the window/stopping the app because you’re getting those scary error messages) will cause you to have no results.
Go into the advanced features and add the argument “-really-quiet” to the command lines there (to get rid of the scary messages), then try again and be very patient.  You may actually get your file converted after all.
Worked for me.
