I just purchased a Kingston 8gb Micro SDHC for use with my Fuze. I have converted two videos to AVI via Nero and then to the microSD in my Fuze via SMC. Both videos freeze the unit shortly after starting them. I have been able to play videos from the Fuze internal memory. Is this an issue with the Fuze or just my luck?
Thanks.
Other people have reported similar problems with using Kingston memory cards and videos. Use the search box and type in ‘Kingston’. That should find all the discussions on the subject for you.
Thanks Tapeworm. Sorry, that was not one of my searches. Back to Amazon the extra card goes.
No harm, no foul. I was just letting you know that if you wanted to read more on the subject, you could by initiating a search. There has been quite a bit said on the subject.
I wouldn’t necessarily take it as a hard & fast rule though. Some people have claimed compatibility issues with the Kingston brand of cards, where others have experienced no problems. In the end the decision is up to you.
As the saying goes, “Your mileage may vary!”
