Vault missing
Hi, I plugged my USB into my hard drive and it asked me to register a new vault, my old one has gone missing. Can anyone help me. It was working fine last week, it’s just disappeared.
:smiley:   Hi ljjoosub,
_ Dear member of SanDisk Community, welcome. _
Well, I understand that [SecureAccess Vault] folder, disappeared from your UFD, ie it was deleted “accidentally”.
1-  Then please, do not add any files to the UFD, for not overwrite, the file that was deleted.
And if it was not overwritten by the new vault, there is hope.
2-  Download to your PC (not in the UFD, eye), this utility (totally free) and portable (configured to use to “to touch”):
Recuva 1.51,  http://filecloud.io/pbnlht79
3-  Recovery, save it to your PC, and you check (weight, encrypted files, etc.) to see if it is correct .
4-   Then, the copies to the UFD with this exact name [SecureAccess Vault], and ready.
Luck, and then you tell us, what happened, please.
Regards, Alfred.                                                            (Google translated)
Hi ljjoosub, can you also give us a quick update if the suggestion given worked for you?
