is the Sansa Express SanDisks only MP3-player featuring USB-stick functionality (e.g. plugging it in a pc without needing an extra cable) at the moment?
Thanks for your help!
DreamFlasher
DreamFlasher
Hello DreamFlasher, Welcome to the Community!
The Sansa Express has a direct usb connector, so no need for a cable!
No it also functions as a usb drive. You can drag data onto it as well
Yes, but there are caveats. I live and die on a usb drive. I plug it and unplug it between 3 machines at home and work all day long. I was extremely excited to get the Express so I could do this and get an MP3 player to boot. I bought a 2gb sandisk micro sd card, which is a nice replacement to my old 1 gb thumbdrive.
The only problem is that everytime you plug and unplug the device, it completely loses where ever you are in a pod cast or in your play list. Even if you do the “shut down while playing” trick, it still screws it up. Add tihis to the not-really-random random shuffle, and it is very annoying.
If you intend to use it as a USB stick, just be aware of the tradeoffs.
One other thing, you have to load the device as a MSC, but if you need to update the firmware or sync songs or playlists, you need to be in MTP mode. That is another annoyance, but in this case, I don’t think Sandisk can do anything to fix it.
Well… thank you for all your answers, they were helpful in anyway - but I am sorry to say; you did not answer my question. I will try to explain better: I want an MP3 player with an USB-plug (“no extra cable needed”) - and I know the Sansa Express has this. BUT: Are there other players of SanDisk having this, too? I hope I articulated a bit clearer this time ![]()
At this time, that is the only SanDisk Sansa MP3 player, with that feature.
Thanks Baggage for the short and pregnant answer! Your forum is great ![]()
I’ve seen this at Wal-mart:
http://shopping.yahoo.com/p:Samsung%20YP-U2JXB%20Direct%20Insert%20USB%20MP3%20Player:1994092230
Don’t know a thing about it, but it almost looks like a rebranded express. Button layout and everything. Doesn’t come with a lanyard, and doesn’t have expandable micro-SD card support, so not sure why you’d consider it over the express, unless it is less buggy.
Message Edited by akerkhof on 08-17-2007 10:18 AM
