Hello Again Fellow and Future Clip Plus Viewers,
First Just a Little info on Myself ,and How much I Paid for This
SanDisk 4gb Sansa Clip +
Male/Calif./U.S.A./low 50’s/Inventory Trade
BestB-50 Bucks(49.99) plus 10 for 2yrs Warranty-BB/No Extras yet//Armband/Shells/Wallets/etc…
+'s >> The Clip on the Back Works Great,Buttons are easy to Navigate through Menu’s/Lighting Very easy to see ,except in Bright Sunlight,Bright light Blue only,(can be adjusted) looks good/
>+'s for Earplugs that came w/ Clip +//Great Sound All Around (When you get a Strong Station) easily adjusted by moving earplug wire or cord Around a bit when weak/Very Comfortable to Wear All Day/Hrs-and when you do get tired of Wearing them in your ears,Just hang them backwards over your ears…/end of earphone plug Gold Color,not sure gold tipped or plated ,Gold anything Good Conductor/Sleep Feature Works great/Can’t wait to get a Card !
-'s >>Earplugs//Looks like you just bought them at the Dollar Store/I will prob upgrade later,(But Remember They Sound Great !!)/ Left and Right Indicator way to small (eye strain just to see them) so I put a small corner of a old sticker on the right one ,on the inside of the plug ,not seen from the outside,works great!/Volume Control needs a lower setting to Fade(low) and then Back to High//Default Setting for setting your Favorite station starts at [Delete All your Pre Set Stations?]not good start when selecting save /
PS.- Paper Pamphlet(given) on the Back says:For Full Sansa Clip + user Manual is Available at
Until Next time Fellow and furture Clip + Viewers
for more +'s and -'s as I use this Mp3 so far…Very Happy Still :smileyvery-happy:
Laters and Take Care
