uninstalled Rockbox or so I thought
‎06-20-200909:34 PM
Ok so i decided i was going to try to put Rockbox onto my Sansa e250 and although id like to think i am, im not all that tech savey, im not dumb but im no einstein… so anyway i uninstalled it or at least i thought i did but now when i turn it loads Rockbox but then just says
Rockbox boot loader
Version 4.0
Sandisk Sansa e200
Partition 0: 0X0B 3814MB
Partition 1: 0X84 20 MB
Mi4 size: 93800
CRC32: D83AOFEC
Model id: e200
Bianary Type: RBOS
Can’t Load Rockbox. Mi4:
Read failded (image)
Can’t load Rockbox. e200:
File Not Found
It shows this briefly and then shuts off.
I want to run the original software but it requires me to hold the rew button everytime I boot the player.  This is really annoying. How can I fix this error?
I found a thread on the forums but the link that explains how to fix it was no longer available.
Thanks
@depcdivr wrote:
‎06-20-200909:34 PM
Rockbox boot loader
Version 4.0
Sandisk Sansa e200
Mi4 size: 93800
CRC32: D83AOFEC
Model id: e200
Bianary Type: RBOS
File Not Found
Thanks
In most cases with Sansa players the final step to uninstalling Rockbox is to perform a stock firmware install…but I have no idea which one to recommend you to use.
I got nothing on top of my head for this but were you able to find any luck yet?
