i’m looking for help for my fathers’ e260
i start it up and it says it failed to load rockbox. i just reformatted it but still it won’t work. after that message it shuts off. message lasts like 2 sec on screen.
what firmware should i get??
thank you
thank you
Will it start up in the OF? Maybe you need to re-install Rockbox. You should be able to force a connection (either Recovery Mode or MSC) depending on whether you have a v1 or v2 model.
You can find firmware for all SanDisk product in the Sansa Firmware Thread.
Test
