Ultra USB 3.0 32Gb not found on windows 10
Hello, after having issues with windows 10 and not being able to sign in to Microsoft accounts. I’ve just done a fresh install & all updates. but now my Ultra 3.0 is not seen on that machine dell e6230. It shows in the bios, but not in device manager or disk manager it works on every other device in the house, but my main pc.
any suggestions would be greatly appreciated
Sounds like you need to find a tech shop near by and take your rebuilt Windows 10 system in to it.
@ed_p thanks for the suggestion, but there is not anyone that local to me, well with in 30 mins and would probably be cheaper just to buy another stick as the one that I used to install re install windows with works on that device and is the same type :person_shrugging:
