I cannot create a playlist/golist of podcasts. On my old Clip I could do this…how do I do it now? I have tried windows media player and it syncs them into alphabetical listing. If I select the podcast on my Clip, hold down the center button it tells me it is adding it to the Golist…but it doesn’t…I called technical support about this and the only thing they could do was attempt to show me how to sync through WMP…which will work, BUT NOT to create a playlist of podcasts.
The only way I found to allow me to get regular playlists to display properly on my Sansa Clip is by doing the following (my Sansa Clip is set in MSC USB Mode. Also keep the firmware on the Sansa updated).
*.m3u playlist file:
#EXTM3U
Artist - Title.mp3
Artist - Title.mp3
etc.
The songs in the *.m3u can’t have a path before the filename, so the songs must be in the same folder as the *.m3u. You also need an extra line at the end of the *.m3u.
The following are some more stuff I did to make the Sansa Clip a bit friendlier:
The ID3 Tag (any version) must have Artist, Title, and Album to display correctly.
If the song still displays incorrectly:
Capitalize initial letters of all words, e.g. Alice In Chains - Man In The Box, except genre names
Make all genre names lowercase (makes displaying the songs by genre more functional).
Right-click the song, click Properties -> Summary tab, remove odd symbols from comments or delete comments entirely.
Removing East Asian text corrects the tag sometimes (not sure how well this works).
I solved my golist issue I mentioned above by reflashing the firware to .20a. Why they eliminated the ability to add podcasts to golists in the new firmware is beyond me. Perhaps this is a glitch.
