I’m trying to get playlists working on a new, updated 2GB Clip. Working from XPPro, SP2. I have many songs/artists on the clip, and they are visible by browsing in explorer, which sees the Clip as “SanDisk Sansa Clip” under MyComputer.
N-bob, please, when you say
“To create a playlist, all that’s needed is to start with a music file, and right click Playlist”
Where are you (viewing the clip files in explorer? or where, exactly, in the clip folder tree)?
Do you mean right click on a .mp3 file (in the clip), or just what do I right click on?
When I do right click in the correct place, what should I see/do in the rightclick menu?
Or are you in WMP?
I tried (while browsing in the Clip via explorer) right clicking music files, the Playlist folder, and any thing else I could think of, but those right clicks don’t seem to bring up anything having to do with a playlist. Only the typical file ops like Open, Copy, Delete, Properties are in the right click menu. If some other option (like “make playlist”) should be there, then what am I missing (driver, patch, seting, etc) in that regard?
I **think** I’m using MTP, cuz it has the more complex menu system, cuz I *think* using MSC gets only the more primtive style folder.
Dave
