Hi there ! First post here and unfortunatley, its about a few problems.
I’m having problems with plalists and don’t knw how to fix. Ok, I create the playlist in Nero in M3U format, encode the files
off a CD to MP3 and then using Wexplore, copy them to the Clip. The playlist goes into the Playlist folder and the MP3s
into the Songs folder. Ok, this worked sorta fine for the first three playlists. Now herer are the problems:
- When I try to play a playlist from the playlist folder, it shows the playlist as empty. The playlist does however show up
in the Albums folder and the first three played fine from there.
- Ok, the fourth one I added shows up in the album folder as Unknown for a title. It plays all of the songs fine however.
It shows up in the playlist folder as Unknown and ‘empty’ when I try to play it from there.
- The fifth one I added does not show up in the Albums folder at all (the only place I can play any of the playlists from).
It shows up in the playlist folder, but shows up as empty when I try to play it.
I used the exact same creation and copy method for all of them and am obviously getting different results. All songs
I copied over show up as individual songs and play just fine. The playlist function is highly unreliable at this point.
If anyone has encountered this problem and have a workaround, please let me know. I do enjoy my clip, when it acts right.
I just want to properly finish loading all my music and playlists so I can listen to my favorite stuff when I’m practicing my golf
swing at the driving range.
Thanks folks !
