Hi, I have word of promise Bible. basically each book is a folder which contains the respective chapters inside the folder (mp3 format). The problem is if I copy the folder over to audiobooks only the first chapter is available. If I copy to music it is no longer sorted out by folder. Essentially I want to go to Matthew folder and in it I want to be able to access all individual chapters in Matthew. in Mark I want to access all individual chapters in Mark. Right now in audiobook I only have access to Matthew chapter 1 and Mark chapter 1 even though there are many individual mp3s within these folders. If I copy these folders to music every individual mp3 is available not sorted out by folder. Ant advice on how to do this would be appreciated. Thanks.
HI Miikerman,
Thank you for the response. I am not sure if i am using a clip plus. The device says Sansa on the front, on the back it says SandDisk 4GB. Upon further investigation i did notice what the issue could be but I am still not sure how to fix:
I will give a brief example:
I may have MP3s in a folder called 01_Matthew they are called: 01_matthewchapter1.mp2, 0!_matthewchatper2.mp3 etc.
I may have a folder called Mark and in 02_Mark there are files named 02_Markchapter1.mp3, 02_markchapter2.mp3. This goes like this for all 66 books. But on the Sandisk player when I look at the folder called Wordofpromisebilble it shows up in this order 01_Matthewchapter1.mp3, 02_Markchapter1.mp3, 01_Matthewchapter2.mp2, 02_Markchapter2.mp3, 01_Matthewchapter3.mp3, 02Markchapter3.mp3, etc.
So if i played it in order it will play just like this. Matthewchapter1.mp3, markchapte1.mp3, matthewchapter2.mp3, markchapter2.mp3, etc.
As you see i would be listening to the first chapter of all the books of the bible then the second chapter then the third, etc or i would have to scroll through 65 mp3s to get chapter 2 of matthew.
What i would like to do is have an album called matthew, go into that album and listen to all of the chapters. an album called mark go into that album and listen to all chapters, and so fort.
Any advice would be greatly appreciated.
I think I’ve got it. Thanks for all of your help and information.
It was indeed an issue with the tags. I went into each folder while mp3 s were on my computer did a select all (makes it a lot quicker) then I chose properties and adjusted title artist and album. By doing this it did indeed work and separated all books as I expected.
I have the similar problem. My Clip+ sorts the audiobook files in a very strange way. The files in naming convention like 001-name.mp3, 002-name.mp3, …,0214-name.mp3 are sorted in the following way:
010-name.mp3
020-name.mp3
030-name.mp3
090-name.mp3
100-name.mp3
110-name.mp3
190-name.mp3
200-name.mp3
210-name.mp3
001-name.mp3
011-name.mp3
021-name.mp3
031-name.mp3
091-name.mp3
101-name.mp3
The tagging is correct. What can I do to correct the sorting?
Thanks.
jarekt70, what do the title tags look like? I get it is sorting based on the title tags. Use a good tag editing program like mp3Tag. Give all the files in the book the same album tag. Use the track number tag to order the files.
The sorting is not in a numerical way as 001 is after (greater than) 010 for the player. It seems that it sorts based on the 3-rd digit in the first place and then based on the first two digits. If this is the rule, the sorting is correct although I don’t understand why. The sorting is correct when the number in the files is two digits only (a different audiobook). I’ve tried adding “part” in front of the name but it didn’t help.
The title tag value is like the file name. All the files have the same album tag. So It is not the case.
I found a possible cause of the sorting problem . The track tags was set like “001/214”, “002/214”, …, “214/214” but the player sees it all as “214”. When I changed the track tags for simple 001, 002, …, 214 it started to sort correctly.
Just to summarize - it seems that the player does not support naming convention for track tag like “<track number>/<number of tracks>” and additionally it has an issue sorting files having numbers with more that 2 digits.
'Just to summarize - it seems that the player does not support naming convention for track tag like “/” and additionally it has an issue sorting files having numbers with more that 2 digits. "
i have not had any problems with the player sorting 3 digit track numbers. Having the numbers with leading zeros is what is needed, ie 001, 002,… , 099, etc. I do find it easier though to start numbering at 101 when using 3 digit track numbers.
'The sorting is not in a numerical way as 001 is after (greater than) 010 for the player."
That doesn’t sound right. are you sure the first or second digit is the number zero, and not the letter O? i get the tracks in order, then use mp3Tag to autonumber them. When numbering manually or entering tags manually, one blank space that goes unnoticed somewhere will alter the sort sequence. That is why using an autonumbering function avoids these problems. I also got some strange sorting of files until I started using the mp3Tag autonumber function.
That’s correct, it does not.
I double checked the names. I can confirm that it is 001 (zero zero one) not letter O. In fact, the names and tagging are correct and are sorted correctly in both my computer file system and mp3Tag. Of course it is the case, when the tag track is in format 001/214. When I corrected the tagging to with simple number it sorted correctly.
If you edit the tags on files on the player itself, the files might not sort properly. You need to edit the tags on the copy in the pc, delete the copy in the player, then copy them to the player again.
It seems that editing tags directly in the player is not the problem in my case. When I changed the track tag directly on the player it started sorting correctly. Every time I disconnect the player from computer, it updates the files library.
I had a similar problem, an MP3 course with 167 files.
For my case, on the Clip+, I used EasyTag to remove the 2nd part of the track number, so instead of
01/167
the track number became
01
in the MP3 file’s header (ie, the ID3v2 tag). I verified this using the ‘id3v2 -l’ command in Linux.
Once I got rid of the total number of tracks, the sorting worked. YAY! I’ve been using the Clip and Clip+ for years and this audiobook sort problem always bothered me. Thanks to the posters here for sorting this out!
Systemcheck, that was it! I’ve been fighting with this for a few days now and it was driving me crazy. I found if a book had more that 100 tracks, it would fail, less than 100 was no problem. I started to split books into pt 1 and pt 2. But, like you said, in EasyTag if you delete the second part of the xx/xx then it works fine past 100 tracks.
I think it’s pretty clear this is a bug.
Good work-around, though. Thanks!!!
