songs in order in folders
how can i make the songs in some order into folders and after it to here them on the mp3 in the same order?
what is the folder named “audio files”?
thanks
 tochnitanit
The only real way to do what you are asking is to use a playlist. The Clip reads Id3tags that are embedded in the song files and then on the player they are sorted alphabetically. If you make a playlist with the order you want and then add that to the player, you can listen to that and they will be in the order you want.
