Hello, it is my 1st message herre. I bought my sansa clip zip two days ago and I have registered just to write this. I think this kind of things should be as easy to use as possible, and any problem you may encounter only gives you a headhache.
I have the 8gb version and I have stopped copying files becuase of the disorder. I am not interested in music, but mainly in podcasts and mp3 files downloaded from people who make different stuff. I copy my files with simple folders to be organized, using MPT mode (or MSC, doesn’t matter) and when I turn on the sansa clip zip there are many files that don’t appear. Also the folders are not present and all files are shown in the same “unknow” folder. I use Windows 7 and all files are in mp3 format and I can listen from any windows player.
For any reason even the files are nor shown alphabetically, so de chaos is total. I have tried to use “folder” way to play files, but the folders are shown with a lot of numbers that make difficult to navigate and recognize easy, and also this way present others limitations.
I can’t believe what is happening…, a thing like that should make the life easier, not to present that kind of problems. I only ask for a simple way to have folders and files, and navigate to find the right file… is it so difficult?
