Hello, I’m new here, and I’m going slightly mad trying to transfer music to my daughter’s new Clip+. Basically I have been syncing files from Windows Media Player and was baffled by the fact that while some files transferred perfectly smoothly, others failed to show up on the Clip itself, although they appear to be there when I check on the computer (in Windows Explorer).
It then occurred to me that maybe the ones that didn’t show up were in a different format, and yes, they are m4a, not mp3. SO I found out how to convert m4a files in iTunes to mp3 and then copied those versions over to the Clip. Now they are actually physically on the Clip, HOWEVER the folder is listed as “Unknown”, when on the computer the folder in question has a name (obviously). Why is this? And what can I do about it? Editing the folder name on the computer doesn’t make any difference.
I cannot believe how complicated this is turning out to be, I’ve literally spent hours trying to sort it out. Help please…
