The SMC video conversion and transfer software is a piece of ■■■■! It crashes often and is agonizingly slow. If you have a Sansa View (which is a really nice unit, of which I own the 16GB version and enjoy much), I suggest that you do the following…
First download and install a free and easy to use video file conversion software called “Format Factory” at the following link: http://www.formatoz.com/
Since the Sansa View supports MP4 files, you will need to use Format Factory to convert your video files (if not already in MP4 format) into MP4 files, then copy the MP4 video files over to the “Video” folder in the Sansa View using (and within) Windows Explorer. Windows Explorer will recognize (“see”) the Sansa View as another USB MSC (Mass Storage Class) device, as long as you set the View’s USB connection as a MSC device.
Here’s what has worked and is working for me:
1. Go to the [View] player’s Settings menu and under the “USB Mode” menu set the player to MSC mode. This will set the player to be recognized by Windows Explorer as a USB storage device; the player will show up as a new drive listed as “Sansa”, or the micro SD expansion card as another drive as “Expansion: x”, with x being the logical drive letter assigned by Windows.
2. Install and use the Format Factory software to convert your video files into MP4 files as follows:
3. Select and use the “Mobile Device\PSP\Phone” tool (on the left hand side).
4. Select “All to Compatible MP4” tool. A new window will pop up.
5. Click “Add File”. Then find and add the appropriate video file(s) you want to convert, and click “Open”. You can select and add more than one file to convert – the program can perform batch conversions. You will see the file(s) added into the file window to the left.
6. Click “Output Setting” (do not click “OK” yet since you will need to set the conversion settings for the appropriate converted video specs in order for the file to be played on the Sansa).
In the Profile dialog box (upper left) select and click “Custom”.
7. Check to make sure of the following settings; change if needed by clicking on the appropriate Setting Value boxes (a drop-down menu arrow will appear and will give you various choices) and change the settings for the following:
Video Size = 368 x 208 for widescreen format, or 352 x 240 for Standard (TV) format. If your video looks squished or stretched, try other settings
FPS = 30
Bitrate = 384
Video Encode = MPEG4
Keep Aspect = NO
Audio Sample Rate = 44100
Bitrate = 128
8. Click “OK”
9. Click the “Start” button on the tool bar up above. It takes about 35 to 45 minutes to convert a full-length Hollywood movie.
10. After the video has finished converting, the program will place the MP4 video file in a folder named “FFOutput” in the “My Document” folder of your PC.
11. Connect the Sansa player to your PC using the USB connector.
12. Click the “My Documents” icon on your PC.
13. Go to the FFOutput folder, find the appropriate MP4 file, and copy the file to the Sansa player in the “Video” folder, or the Sansa’s expansion card (but first make sure you create a “VIDEO” folder on the expansion card).
14. When you disconnect the View from your PC, let the player refresh its database. This may take a few seconds to a minute or two depending on how much contents you’ve just transferred.
15. Then go to the video section, watch, and enjoy.
Good luck!
