This was too easy so I decided to share. I signed on for the 1 month free trial but decided not to continue (I prefer to either buy the CD or download individually - no monthly fee for me please). Unfortunately my Fuze had other ideas.
Rhapsody just wouldn’t stop with the “subscription tracks have expired” every time I turned the thing on!
So if you just want to get rid of it…
Plug in your Sansa
Go to Start - the select My Computer (I have WinXP - I’m sure there is something in Vista like it)
You’ll get a list of hard drives etc. At the bottom should be your Fuse or other Sansa
Double click on it
Look for a folder called “services”
Go there
Inside you’ll find a folder called “Rhapsody” - Delete it.
That’s it folks.
Only took me 2 hours to figure it out
Hope this helps
