I used the 30-day free Rhapsody trial but elected not to renew it. Now I can’t seem to get rid of it.
(1) I continue to get the message “Your subscription has expired. Connect to your PC.” everytime I turn my Clip on.
(2) There is also a large “zero” next to the battery indicator on my screen. I’ve read somewhere that it indicates the number of days I have to renew my Rhapsoday subscription.
(3) The 3rd problem is there is a “Rhapsody Channel” choice where the “Music, FM Radio, Voice, Recorder, etc” are listed.
Do you guys have any idea how I can fix these annoying problems? Immediately after the 30-day free trial expired I “Reset All” and lost all my music so I don’t want to try that again. Thanks for any suggestions.
Two methods to get rid of Rhapsody:
- Place the Clip on the floor, and step back. Raise your hands in the air, flail them about, run away, and scream like a little girl, yelling “clowns will eat me!!”
2. Oh, that didn’t work? On the device, select Settings > Format > Yes. Poof. No more Rhapsody data. UPDATE! For those in a similar situation, formatting clears all data, not just the Rhapsody music files. I’m old school, starting with 1-inch tape drives and 12 inch platter drives. To format is to write nulls on the entire platform, a clean sweep. (I assumed that the only music here was the Rhapsody content!) Bob
Let me know if your wee dot and nag screen disappear!
Bob :smileyvery-happy:
Message Edited by neutron_bob on 08-09-2008 07:14 AM
Running around yelling like like a little girl didn’t help at all. However, reformatting worked wonders…no more Rhapsody! You are my hero. Thanks!
Well, now you’re not my hero. I just discovered reformatting deleted all my music…bummer. Guess I have to start downloading all over again. Thanks anyway for trying.
All you have to do, is:
connect the device to your PC, using a USB cable
open Windows explorer, and find your SANSA device listed
click on the “+” sign next to the device, then go down to services.
click on the “+” sign next to Services, and you will see Rhapsody listed as a service.
click once on Rhapsody, then hit your delete key. This will remove Rhapsody from your device, WITHOUT DELETING ALL OF YOUR MUSIC.
now disconnect the SANSA device from your computer, and power on. you will no longer see the message.
Props to me for not making you delete all of your files.
He warned you in the post haha.
