When I boutght my Clip I signed up for the free trial period of Rhapsody – but find I don’t use it, and don’t really need it to get music on to my Clip. Is there a way of removing it from the Clip?
fwt
fwt
Format the device.
Unplug from the Computer,
Go to Settings>Format>Yes
It will remove Rhapsody from the device (and everything else with it, youll need to transfer content again).
Sansa Clip
OK I have same issue. Don’t use Rhapsody anymore.
Removed what I think are all the songs by plugging into computer and deleting.
Just have my CD’s now…but can I just delete the Rhapsody program from the service folder via my computer? I don’t want to have to reload if I can help it…but I don’t want to mess this up either.
Thanks
