Since I updated my MacBook from Mojave to Catalina SecureAccess just crashes a few seconds after launch.
I tried it on a USB stick and a portable SSD both with the newest version of SA and I even tried different file systems, since I first encountered the issue on my NTFS formatted SSD (macOS has natively only read compatibility with NTFS, but with some tools can write too), so i tried exFAT and FAT32 too with the same result.
Another thing I observed/tested:
When I used the Windows version to create a Vault on my SSD with a password and some files in it and then opening it on the MacBook via the mac version, SA didn´t crash but after typing in my password i got an error message saying the vaullt could not be loaded. But when I open it on Windows again everything is working.
My guess is that because of some changes to filesystem permissions made in Catalina the mac version of SecureAccess needs an update. But it could as well be some wierd issue with my MacBook, so it would be great to get some feedback if someone else has this problem too or even knows a solution to it.
Cheers,
MV
