Secure access already running
I have a 128GB 3.0 USB drive. The drive was running fine and was full until it suddenly stopped working. The error message is “sandisksecureaccess is already running”. As suggested I renamed the lock file to lock2  which allowed me to enter my password but not to access any files (which I can’t see).  I deleted the lock file without success. I can not reinstall the software as the drive is too full to install the software again without deleting files.  Help, please.  Thanks.
Wow!!  I don’t know what to tell you Greg.  Try safely ejecting the flash drive and rebooting.  Try emptying your Recycle Bin.  Try the drive in a different computer.  See if any of those free up some space on the drive.
Be very careful deleting Vault files unless you have a mirrow copy of the drive that can be restored.
Thank you Ed for your suggestions. Nothing is happening yet.
One observation that may hold some critical information is that when I get to the screen where the my vault screen it shows there are 0 files in my vault. But when right click on the the USB home screen icon and use the “get info” selection it shows that the USB drive is full to capacity. does that provide any clues?  Thanks again
Greg
Yes, that you’re screwed Greg.  If you can’t signon to SecureAccess or it shows 0 files it doesn’t matter how full the drive is, the files are encrypted and the only thing that will decrypt them is a working SecureAccess.
Sorry Greg.  I wish I had better news.
Try https://kb.sandisk.com/app/home/
Greg, see if this posting helps.
http://forums.sandisk.com/t5/SanDisk-SecureAccess-2-0/Showing-error-and-my-all-family-pictures-are-encrypted-in-vault/m-p/337263/highlight/true#M475
hey ppl
good news
do the following please
In the folder on the stick  “SanDiskSecureAccess Settings” there is a file called “lock”.
The highttech solution is to rename the file 2 something else and voila…everything worked.
I have renamed lock to lucky … but it did not work.
I have also tried to copy the new downloaded SanDiskSecure ACCESS V3_win (latest rev.) but I am unable to copy it to the flash drive as it keeps telling me that it does not exist (as far as the computer is concerned).
Please help!
Strange. If you could rename a file, a better approach than deleting I might add, your system, Windows 10?, has access to the drive so whatever app you used to rename the file should be able to copy a file to the drive.
From a Command Prompt run a chkdsk command for the drive. If it shows errors rerun it with a /f option. Then use Windows Safe to Remove the drive and reboot.
