Hello, My Sansa was playing fine etc., today put in a extra 4 GB and re hooked it to my Pc and it has froze it does not want to shut down or nothing so tried and took off the extra 4 GB and retried it and nothing, oh by the way prior had updated to the latest firmware. I am lost on what happened to it had it a month or so only, any help would be appreciated.
I would recommend first to format your card - you can do it via your computer formant function - and have a look how the Fuze is going to behave after this operation. There might be some corruption of FAT on the card itself having nothing to do with the new firmware.
You might try a manual install (back to 1.02.26), but be warned. You’ll probably be wasting your time.
I’ve tried that install on two different Fuzes, and the results, if you can believe this, were even worse. These devices were turned into useless junk. I then reinstalled the latest version and the devices were returned to their semi-uselessness.
Also, you can be assured that your problem isn’t the result of a bad card. Removing the card, inserting a brand new card, or reformatting the card, had no effect on solving the problem.
I’ll try a couple of dozen other possible solutations and get back to you if anything works.
Sorry, that I did not reply earlier guess that did not subscribed to the instant reply but resolved the issue by just letting the player run out of juice and taking out the 4GB and it played like a charm in my car. Know have the same stupid problem so will re-do the same procedure and see what happens.
Well its working again, this is nuts could it be the 4GB since every time I insert the disk it goes bonkers, any site on this and feed back would be appreciated.
I wouldn’t be so quick to blame the card; it’s a rare instance when they fail and even more rare that you get a bad one new. More likely is the fact you have something on the card that the Fuze is choking on, like a corrupted song file, bad (or wrong format) ID3 tag, or questionable content received from file-stealing sharing sites such as Lime or Frostwire.
I’d try running ChkDsk (error-checking) on both the internal memory and the card and see if anything turns up. Then get MP3Tag or another dedicated tagging program and make sure all tags are ID3v2.3 ISO-8859-1 format. While you’re into the tags, delete any and all information in the Comments field.
I’d try running ChkDsk (error-checking) on both the internal memory and the card and see if anything turns up. Then get MP3Tag or another dedicated tagging program and make sure all tags are ID3v2.3 ISO-8859-1 format. While you’re into the tags, delete any and all information in the Comments field. This can really screw with the Sansa wee brain.
