OK I’m all out of ideas on what to do. Here’s my problem.
My old computer bit the dust, this was the computer that my Sansa E250 was synced to. I don’t have the disk so when I tried plugging it into my new comp it wasn’t recognized. Well looking up solutions to the problem I found out about turning the device to MSC mode. This took care of the problem of my computer not recognizing the device. It showed up on my computer, so I thought all was well and went to sync a song to the device.
It said the song was “successfully synced to device”, when I went to listen to it I noticed I now only had 39 songs on my device when I originally had 350ish. To make matters worse, it still showed all the space being used, out of 2GB I only had 34MBs left. Which is the amount my 350 songs is using. AND the new song wasn’t even on the device.
I did the firmware udates and such, it did the upgrade and restarted but alas, 39 songs and 34MBs of space left. Not only that but when I look at my device on the computer it doesn’t show any songs, and that song I just added cannot be deleted. When I try to add it again, it says it’s already on the device.
I’m sorry if I didn’t make my problem clear enough and rambled but I’m terribly confused as to what the f just happened to my player. So QUESTION: Where’s is my music? Why is it still taking space but not on my player?
Also if this helps, an error message came up when I plugged my sansa back into the computer, it’s as follows:
WINDOWS- NO DISK
Exception Processing Message c0000013 Parameters 75b6bf7c
Thank you for your time and any help you can offer!
