I went through a LOT of steps to do this, and I also created a portable app out of it, that way it does not require administrator privileges.
Download:
Sansa Media Converter -83mb
How to use:
Open the downloaded file: Sansa Media Converter.exe
- If it says Windows protected your PC: Right Click the downloaded file and select Properties. Then, check Unblock near the bottom right. Click Apply, then close out the properties window and repeat step 1.
After the application successfully opens, close the application.
Make sure that your Sansa Fuse is in MTP mode. In the device’s settings:
Settings - Usb Mode - MTP
- Plug your Sansa Fuse into your computer.
- Repeat step 1.
- Click on your Sansa Fuse device as it is show on the left-hand side of the application under Information.
- Select Add Media
-Notice: if a video can not upload: convert video to avi first then repeat step 7.-
- Select your video file then press convert
After the conversion is finished, unplug your Sansa Fuse and let it update media.
Scroll over to Videos and select your converted video.
If you have any questions or concerns please email me here:
techybypasshacker@outlook.com
