sansa firmware undater
I downloaded the sansa firmware updater, then it allows you to download the sansa manual, and the sansa media converter, but when I put a check mark in each box, I try to press the download button and it will not acitvate?  And I need the media converter in order to transfer photos or videos into my sansa fuse?  Anyone have any suggestions?  Thanks
There seems to be a bug over at SanDisk with the Media Converter.
Don’t bother with it. Get Video4Fuze instead. It works better.
And while you’re at it, uninstall Updater. There won’t be any more updates.
I think the spelling in your Subject line is more appropriate. :smileyvery-happy:
