Please send me an up dated converter for my Sansa Fuze. Thank you!
You have to download & install the Sansa Firmware Updater to get the Media Converter.
Or you can use one of these alternatives.
Thanks man, but my sansa fuze seems to be not working. Now it will not turn on.
Probably just needs a reset. Slide the spring-loaded power switch on the side up to the farthest most position and hold it there for a slow count to 20. Release and see if it will start up normally.
thanks alot it started up again. gee you guys are so awsome.
