i have a sansa connect 4g - and i am looking for a media converter - the sansa media converter won’t download from the sansa updater for some uk reason does anyone have something i can use ?? help
Message Edited by bongo30023 on 02-08-2010 10:33 AM
The Firmware Updater doesn’t recognize the Connect, and therefore doesn’t proceed to the step where it gives you the opportunity to download the Sansa Media Converter.
You can use another tool, like Any Video Converter, to convert videos into a format that the Connect supports. If you do use Any Video Converter, select the format “Customized MP4 Movie (*.mp4)” and change the settings like so:
Video codec: mpeg4
Frame size: 320x240
Video bitrate: 512
Video framerate: 15
Audio codec: aac
Audio bitrate: 192
Sample rate: 48000
Once you’ve converted the video, use Windows Explorer to copy it to My Computer\Sansa Connect\Internal Memory\Video. I think the Connect will also pick up videos copied to an inserted microSDHC card.
thanks for u’re help ! if this is a stupid question i’m sorry where would i find “any video converter” ??
i found the any video converter thanks again trying it out let u know
