If Audilbe is supported on this model (and I don’t think it is), then you would need to use Audible’s software and MTP mode on your player in order to transfer the DRM-encrypted files and licences over.
Check Audible’s website and see if the m200 series is in the list of supported players.
If Audilbe is supported on this model, then you would need to use Audible’s software and MTP mode on your player in order to transfer the DRM-encrypted files and licences over.
Audible does support the m200 series but when i try connect my m250 with the aduible manager , i get this message : " To support Audible on your device, you need to upgrade your device’s firmware."
