Is it possible to play itunes songs on my m250. I think I downloaded some (it looks like a lot of memory is used) but they will not show up on the screen nor play. Are they in a different form or protected. Can this be fixed? If not then how do I get them off?
By the way is guess you can tell I am new at this.
Most Itunes purchased songs are copy protected using Apple’s DRM (called FairPlay) and thus can not be played on any device other than Apple ipods. Apple’s encoding format is AAC which I think is also incompatible with the m200.
The Sansa devices support a different DRM scheme called PlaysForSure from Microsoft.
The choice I have is " !(file:///C:/DOCUME%7E1/OWNER%7E1.YOU/LOCALS%7E1/Temp/moz-screenshot.jpg)convert selection to ACC" When I try that it pops up a window saying a protected file can’t be coverted.
