I just updated the firmware and added about 5gb of music. It loads to about 15% then stops. After an hour it still hasn’t moved. Is there a way to fix this?
Mine did the same thing. I turned the Fuze off, waited about 30 seconds, and turned it back on, and it “refreshed” everything (16GB) in about 2 minutes - and you could see the progress bar moving (not “stuck” in the same position).
I already turned it off and on about a million times. It doesn’t help.
According to some of the posts here, a bad tag or two will cause the player to hang during refresh. It’s possible some of the tags in your new 5GB of data are bad. You probably need to download a good tagger to fix.
