@xpmule wrote:
Thanks for the update
Hint Hint… Looping menu’s
seriously though GJ sansa people appreciate the effort
Seriously, looping menus would be excellent. and is needed.
You said that you use in-ear monitors with double flanged ear tips, then would you suggest the JLab Audio J4 earbuds, the reason why is that I got a pair for cheap rather than priced at their $40 markdown. In all the of midst of that they sound “alright” to me and do a good job of blocking out all other sound and can thump a bit. Also what EQ settings do you use and if you are using the custom setting, could you explain what frequencies that you prefer to sound better at different db. Much appreciated :robotvery-happy: !
Hello is there a place to report bugs?
IMO:you can mention it here or at Fuze+ feature request thread.
Moved this post to a new thread for visibility.
BTW,
It appears that the clock doesn’t keep up with the time when I plug my player in to charge. The clock is always wrong after I charge it. What’s that all about?
snuggles the clock doesn’t work for a lot of people and we havn’t gotten an answer why. Mine doesn’t keep time when the player has been offed or after a charge it only ticks when on and then it doesn’t like jump to the right time or anything.
Bug, plz fix. When i press volume up button my sansa fuze+ reset. But press and hold volume up button my sansa fuze+ don’t reset. My fuze+ updated firmware 1.30.01A to 2.37.01A
Isn’t it the Down Volume button?
No, it is’nt.
Just thought i should make a comment on the new update for the sansa fuse+.
As i use my player mainly for listening to audiobooks, mainly as mp3 files, i must say this is hit and miss. When uploaded it is pot luck where they end up most of the time, for instance i loaded 6 books onto my card on my player, and when in the menu ‘music’ or the actual ‘card’ section only 3 and 1/2 turned up where they were supposed to - the half missing was placed in the unknown section even though it has the same info on properties as the other half. The other two missing are probably in the podcast section - though i havent checked that yet, i dont know why this happens as they are all mp3 files!? And heaven forbid you upload a audiobook that has chapters or files listed as tracks, you could spend all day trying to find them all or if they are in the right place they could be all mixed up even in numerical order. I always check all info on the properties details before i put it on the player, but even this way i would say 1/3 of the files end up somewhere else and it really is a pain to have to do this all the time. (this happened before update as well).
Is there no way to get it to play in the folders/in the order that you put them in? As i have had to go back to my prev mp3 player to play the books like this as its soooo annoying!
The new screen lock is loads better though its alot less likely to become unlocked in your pocket!!!
Having said all the above i still really like the player, sound, battery etc are brilliant and the FF RW that speeds up the longer you hold it is great esp for audiobooks, should you have to FF RW a few hrs!
audiobooks and podcasts are seperated on a few different things.
if you place any file in the audiobook, audible, or podcast folders the files will show under the respecvtive menu option.
the genre also will sort the file regardless of the actual storeage location. for example, if the genre is set to audiobook it will show under the audiobook menu option. if the genre is set to podcast it will show up under the podcast menu option. no matter what folder the file is stored in.
once the files is sorted under the correct menu option it will be listed first by ID3 tag and if no ID3 tag is present it will be listed alpha numerically by file name.
to sort by ID3 tag I would suggest setting the Artist to the book name, track to 01, 02, etc for the order you want them played, and title to chapter01, chapter02 etc in the order you want them played.
For sorting by file name i would suggest the following file naming convention. Name_of_book_chapter01.mp3. This will sort them all together and in the order you want them.
note that when numbering the tracks you will need to lead with 0’s. for example if you have 25 files you will need to lead with 01,02 etc if you ahve 100 lead with 001, 002 etc.
when is sansa fuze+'s next update. my f+ realy could use a few fixes
Actually, your username and post sum it right up. The firmware of the fuze+ is currently so userfriendly that is breaks in all possible scenarios, except if you are either lucky or do some backwards **bleep**ed up **bleep** like tagging your files completely the wrong way by putting track numbers in the title tag and Album or genre info in the artist tags etc…
Welcome to the fuze+ user expierence. For the album art, it does work, but read the first part of my post. It only works in some exceptional scenarios, and you need some luck. Basically it boils down to this.
Your album art needs to be…
A. …jpg (actually, maybe bmp works, I never bothered to try)
B. …non progressive (see the options when you save with an image editor)
C. …called folder.jpg and be in the same folder as the audio files or be embedded in the audio files themselves
D. …square (eg.500x500)
E. …if you want to fix the album art for music already on your fuze+, you need to delete the music from the player, unplug the player and turn it on, turn it off and then put the music back on. The player only updates it’s database for new files (well, not for new jpg files called folder.jpg thus, ahem…).
good luck! you’ll need it.
This is another splendid example of how the firmware breaks in every scenario except one very specific one which you could never figure out unless you read about it on a forum.
Decent software design should aim for the opposite. Don’t break except for in exceptional cases. It is not a problem if a small minority of the users manage to break something, but it is a serious problem if only a minority of your users manage to get something working without reading up on forums, contacting support and wasting a lot of their (and your) valuable time…
Good design is a win-win situation. You get paid back a thousandfold in user loyality, increased sales from better reputation, decreased technical support spendings etc, etc, etc…
I couldn’t possibly recommend the fuze+ to anyone right now, and the ridiculous thing is that the hardware seems fine, and the firmware ■■■■. What a potential with this hardware. Get on with it. Have the developers devoted to this and have it finished and thoroughly tested, than it is over. Users happy, you happy… Sales and reputation up…
Great job guys! This firmware update is really a big improvement! The problems with slow playlist and lock are now away! :smileyvery-happy:
I would say that the next step for the next firmware update should be:
Boot time when nothing new is add to the library 30 second boot even with full 16go library is too much (i don’t even have a sd card!)
Audiobook spread in single file if they are mp3
tag mixing up while playing
can one dreams that we get some id3v2,4 support?
keep on the good job!
Is there a difference in updating the player manually or by the updater?
Only the method used. The end result is exactly the same.
Change the genre of your books podcast and they will show up in the podcast section even if they are in the music section. The audio book section is useless. If you leave the genre set to audiobooks they will go to the audio file regardless where you place them. If you are having problems with file order see my postings under " audio books sorted by titles."
You will be enjoying books on your player soon.
Could we get official information and an active timeline as to the complete support of FLAC codec? It seems as though absolutely no tags are well-supported, which is ridiculous. Could we get support for embedded ID3 tags in FLAC? If the standard is already supported on the Fuze+, then that should be feasible. This would really help Linux users as EasyTag lets us add these tags to .FLAC files.
Also, while now the Fuze has a visible device profile in Banshee, it claims it only supports MP3, not even OGG, which is not the case. This is less of a concern, but probably easier to fix. Both would be nice, though.
Thank you for continued support but please, resist writing FLAC as a supported format when it is clearly not in good shape.
Sadly this will remain a pretty but useless tech gadget sitting in my desk drawer until it handles 90% full internal memory and external 32 GB card. I have never before purchased such a promising product which so totally failed to deliver. I check back here every few months to see if the basic functionality of the unit with a decent size music collection is there yet. It is not, and it is inexplicable that the team focuses on these goofy little bugs like tweaking the lock every release, the endless volume bugs and the random renaming of books and podcasts while the unit essentially is completely non functional anywhere near capacity.
The warranty on this thing will be long out of date before I ever get to use it. My money is on Rockbox coming out with a usable release befoer Sandisk does… after Sandisk had a couple years head start.
