I am having a issues with my Fuze and wondering if these are related to firmware and will be fixed or if the unit is failing.
I have a Sansa Fuze v 1 with firmware V01.02.26A. I have a 8GB Sandisk Sd card.
I use the unit it the following way:
I listen to audio books and podcasts.
* I listen to podcasts. I am using the new folder method. I have confirmed the issue occurs using the podcast method as well.
* After listening to one I delete it and move to the next.
What occurs:
1 After listening to a few podcasts, the unit starts acting up. Screen goes blank, buttons do nothing and mp3 plays/stutters every 5 to 10 seconds for about a second. The only way to get it working again is to hold the power switch and restart the player. This causes a refresh (which takes a while).
2 At times the pause button fails to pause. The screen shows pause, but the player keeps playing. When this occurs, the above is not far behind.
3 At times the device is playing and it just shuts off. I can not get it to start again. I need to hold the power button and reboot the unit. This may be related to #1 above.
- At times I get popping while listening. Once the popping starts I know #1 is not too far from occuring.
What I have done:
I reformated both internal and external card as Fat via Windows not the device
I have reloaded the firmware and performed a reset factory settings
I have the unit set USB mode to MSC only.
Any one have ideas on what else to try? Is a firmware going to be made available to resolve these issues? Is it possible to get on a beta of the next firmware?
Next:
I will listen without deleting and see if the issues above occur. I have a feeling the deletions is causing some issue.
