Sansa Fuze 2gb stuck on refreshing media
so like i dropped it in the library and then it had to refresh my min sd for some reason knowing that it  started to show a little progress in refreshing but it stop and doesnt like go nowhere how can i fix this i know nothing wrong with my sd card:/
Try resetting it. Push the power sliding switch on the side up and hold it there for 30 seconds. Release, then push up momentarily and see if it will start up normally.
aww man i think my mini sd slot is messed up :o cuhz i tried another sd it giving me the same response
Does it power up correctly with no card in the slot?
yeahh i can use it without the mini sd card it works fine and everything
uhm just today like this morning idk it was working fine and errthing till it dropped on the ground then i was like whatt why isnt it loading so i had to go listen to my internal music :frowning:
It sounds like something in (or connected to) the card slot definitely got the worst part of the impact when it was dropped. Bummer . . . but it could be worse; at least you can still play from the internal memory.
