I dont care if it’s been asked before. I’ve run out of patience for this piece of ■■■■ thing and I just wanna go to bed and get this solved. It works when i connect it to the PC but it just wont turn on. What if i format it? Help would be greatly appriciated.
This advice from LagunaSansa in this thread worked twice for my e130:
"Try taking the battery out of the Sansa. Let the Sansa sit for 10 minutes. After 10 minutes, hold down the power button for a minute or so. The battery should not be in the player yet.
Next, put in a fresh AAA battery and try turning it on."
