My3 week old Sansa Clip’s FM radio abruptly stopped working. The MP3 player still works. Any suggestions?
You can try to get a good reception or you can try to update the firmware of your player;
Updating the Sansa CLIP.
http://kb.sandisk.com/app/answers/detail/a\_id/300/kw/sansa%20clip%20firmware%20update/r\_id/101834
And if same thing happen you can go back to store for replacement.
I had successfully updated the firmware before it stopped working. I tried several different ear phones to rule that out. Neither picked up any FM stations, but both provided MP3 music.
Do you see an arrow or a box just under the frequency? Arrow means play, box means mute. Try pressing play/pause. It functions as a mute on/off for FM radio.
Good point. I didn’t know there was a mute. Thank you.
